1、Playing the webDav file source will cause the Bluetooth subwoofer to be disconnected, but the Bluetooth sound bar is normal.
2、Playing SMB file sources will automatically return to normal
3、Play with KODI without any problem in TV
4、Other apps on appletv also don’t have any problems
what’s the problem?
DEVICE:SONY tv, Apple tv and sony ht-st5000
what’s the problem?
You only need to post a problem once so I moved your post to the original thread.
If your videos have multiple audio tracks, it’s possible a 2.0 track (without LFE channel) is being selected in Infuse.
You can check and/or change the selected audio track by swiping down while a video is playing and navigating to the Audio tab.
