What NAS should i buy to work with Infuse?
I would stay away from any cheap NAS. In the NAS market you get what you pay for. 4 bay is nice but a two bay will do for home media. Both synology and qnap have excellent devices.
I’d also stay away from any home built solutions unless you enjoy spending time dicking around with things.
Thanks for all the advise.
If a cheap NAS is bad then I might build my own instead. The price will be around the same as Synology and QNAP but more powerful for ‘outside’ the home streaming with Plex.
Another solution could be Netgear X10 router but the home build seems like a more ‘safe’ solution when you compare user experiences.
I’ve run into a bit of a rut lately about external drives. I got a WD My Cloud Home before stupidly realising that it’s locked into its own OS and I can’t get it set up with Infuse through the Apple TV (despite trying many techniques), and I bought a Buffalo Linkstation to try that, the streaming is (reasonably) fine, but the transfer speeds are painfully slow, so I figured I would ask you guys.
What would you say was the best (and most straightforward to set up) NAS drive for streaming content through the Infuse app on Apple TV?
Synology and Qnap make good devices. Try to get one with an intel processor. If you aren’t doing virtualization or anything intensive on it you won’t need SSDs or really fast drives.
I bought a zyexl NAS542, easy to setup for home and cloud
Both Synology and Qnap are well regarded - I’ve a 4 bay Synology.
You could consider a 2 bay unit to save money, and use WD Red drives ( or equivalent) and at least 6Tb i’d say as even bigger capacities are available now…
The Synology software is excellent, but that does mean you may end up with automated tv show content stuff going on, then add security cameras and so on, and end up wishing you got a bigger unit to start with :wink:
Ps Also best to ensure you have a GOOD wifi router, something like a mid to high end Asus - i stream all my content over its 5gHz network without issue ( and keep all our phones, laptops etc etc off that 5ghz).
I second this. WD red or Seagate IronWolf (synology has direct integration with their “smart” features).
As an update.
You need to think if you’re going to run the NAS with any redundancy or JBOD.
My setup is using the 4 bay NAS mentioned with 4 x 3TB drives as JBOD with no redundancy (risky I know).
I use MakeMKV to save just the main movie part to the NAS with no compression. The house has cat5 installed so my 4K ATV is on that network and Infuse connects through my AV amp to feed TV and projector.
My advice and this is what I’d do if I were staring again is if you’re wanting to keep it simple is any of the NAS mentioned with decent NAS hard drives connected direct to the ATV if all its used for is serving video.
Investigate encoding your files from H264 to H265 (this could take a looong time) which will give you smaller file sizes (with no real loss of quality from what I’ve seen) which will help if you want to include any redundancy.
I have a HP MicroServer with multiple 6TB drives setup as JBOD. It runs FreeNAS which is free. Shares are configured as NFS and serve Infuse 1080p/2160p flies without any issues.
Hi there.
I’m new to infuse and am currently just using my PC which always needs to be on as my infuse library. I am looking at getting a NAS so that I can store all the media on there and allow the infuse library to stream from there. I can’t decide between two Synology setups and I am not sure if I need the more expensive one or if the cheaper one will be sufficient enough.
I rip blu rays and have a few 4K movies so it will need to have 4K streaming capabilities (which I believe the infuse app allows)
The two NAS’s are:
DS718+ : this is more expensive but it states it can transcode 4K.
DS218+: cheaper but will it allow me to stream 4K?
Any help will be greatly appreciated.
Thanks in advance
There have been several threads recently about choosing a NAS and here’s one that may help you narrow down your search.
Personally, I’d go for the gusto. While the lesser NAS may work you will most likely find that you could have really used some of the features the more loaded unit has to offer. I’m considering the 918+ myself after spending a mind numbing period of time comparing the options.
Go with anything that has an intel processor. The 918+ and the 418play are virtually identical with the only difference being included ram and the ability to add an expansion bay. The 418play will do all the transcoding you need at a cheaper price. I’d only recommend going with the bigger unit if you plan on running docker images on the unit. One thing to note is all the synology NAS devices are limited to transcoding 4K @ 30fps. Any 60fps content won’t transcode… though this shouldn’t be an issue unless you watch a lot of homemade ripped YouTube content.
Unlike plex, Infuse doesn’t do any transcoding or force the NAS to transcode. It just streams directly from the original file. The only thing to be concerned about would be read speed and network speed (min gigabit ethernet). Assuming your drives are fast enough, ethernet will be the limiting factor, which is plenty fast enough for any 4k streaming.
I have a DS918+ with 32tb myself and it works absolutely brilliantly.
The goal however shouldn’t be transcoding, it should be to transfer the file to Infuse so it can direct play.
I’m still happily using a DS412+ - so that was released in 2012… and streams I can watchinclude 4k over a 5gHz wifi connection (from a good Asus router, not some generic ‘free’ router from an ISP).
Using Infuse allows you to completely avoid transcoding - and you DO want to avoid it (and avoid using Plex to play any media… I have the lifetime Plex Pass and Minix box experience to be so happy to have left that behind…).
If you can, try to go for a 4 bay unit if you want to allow for expanding needs later on - there’s a lot of excellent software for the Synology whuch oyu may end up suing from surveillance webcams , Roon, and much much more…
But otherwise you could start with a 2 bay like the cheaper 218+ which will work fine for supplying media to your infuse, and later on sell it to upgrade once you know that’s what you want to spend money on (and keep the WD Red hard drives anyway… maybe 6Tb or more depending on the price sweet spot right now…)
Hi all,
plz suggest best & cheap synology for infuse pro…
I am using Synology DS218j and its pretty good
is synology DS216play is gud?
The play versions are more powerful versions which support transcoding. If you don’t plan on using plex And transcoding for remote access then I wouldn’t bother with it.
you mean its gud for infuse pro too… its getting me on cheap rate therefore i want to buy
