hi there,
just installed the beta. what is the new "Overflow" menu for? In this menu, i selected "Overflow" in the item "Overflow". Afterwards, the menu was gone. How can I re-activate it?
thanks,
tom
hi there,
thanks,
tom
Haha.
Well, Overflow is to move items out of the main menu into the Overflow folder ... to reduce clutter. For instance, I have all my "settings" and crap in there. Think of it as a folder or a submenu.
You unfortunately entered a Paradox. You put Overflow into Overflow! Granted, that option shouldn't even exist and I have no idea how you fix it, sorry.
Use terminal (ssh into the atv2) to remove overflow using the command:
apt-get remove org.tomcool.overflow
Restart lowtide or enter the command killall Lowtide and reinstall it.
Hi Bomans,
thanks for your post. I did exactly what you wrote but the Overflow menu is still gone. I know that I could reinstall the jailbreaked firmware and ATV Flash but i would like to avoid that. Is there any other simple way to bring the Overflow function back?
thanks,
tom
