What is the best way to upgrade from 4.0.1 to 4.0.3 ?
Hello, im in 4.0.1 and i want to upgrade to 4.0.3, what should i do?
a) Just insert de USB key with the new 4.0.3 and do the magic
or
b) Restore to 3.0.1 and then insert de USB key with the new 4.0.3 and do the magic
Thank you
If you’re running 4.0.1 all the updates can be accessed through the Maintenance > Manage Plugins menu. There is no need to use a USB flash drive.
