What formats are supported without a Pro subscription?
Hello!
While I am a happy Pro subscriber of many years, I wanted to know - what is supported without a subscription?
The website and App Store description aren’t 100% clear as to what codecs would need a subscription. If it’s easier, maybe the reverse description? That is, what codec support does a subscription add?
Thanks!
Codec licensing is a bit convoluted, so there are quite a few variables that go into determining if a particular video requires Pro.
However, in broad strokes, most things with Dolby or DTS audio will require Pro.
