I have a lot of movies which are all fully tagged using MetaTV and MetaMovie on a mac. The movies are connected via a NFS mount called “movies” and tv shows are in a NFS mount called “tv shows”. All files are iTunes compatible tagged. What must i do, that infuse knows what of the file is a movie and what is a tv show. It always put everything underneath “others”.
It only sorts it right, when i use remote data, but many of them are not correct and i already spent a lot of time to do this local. Even when i tag the files in Plex format, they are not sorted into the right category.
