Webdav speed problem
I found a problem with the speed of playing videos on webdav with infuse. If it’s full screen then the speed is limited, if you use picture-in-picture it’s several times faster.
I specifically returned to infuse version 6. The speed of webdav is normal in this version
technical detail :953AV
Look forward to your reply
