Same issue here, only with real-debrid. Does not connect after the last update. I deleted the share and configured it again from scratch, using https, but I still get a message that the username and password do not match (which is false).
Running infuse pro 7.4.6 on an iPad.
I moved your post to a new thread since the thread you posed in had already been marked as solved and your problem is a little different.
Just to confirm, have you selected WebDAV (https) as the protocol in Infuse?
That indeed was the problem. I would have never guessed by myself that this field is clickable. Thank you very much!
Great!
There are UI cues on macOS and Apple TV, and we’ll be improving this on iOS in an upcoming version.
