Thanks for testing.
Would you be able to send in a report from your device and post the 5 digit code here?
Thanks for testing.
01CRK
webdav for ipv6 is working now
A quick note on a UX issue that is affecting some people.
If you are trying to connect via HTTPS when using WebDAV then you will want to select the WebDAV (HTTPS) option. This is currently a bit hidden on some platforms (iOS/macOS) and is something we are working to improve.
If the normal WebDAV option is selected, then Infuse will attempt to connect over normal http (non-secure) which may lead to connection issues with your server.
Today’s 7.4.9 update includes improved support for IPv6.
Thanks for your patience.
