WebDAV - max cache?
I use infuse with WebDAV on my Apple TV. I’m noticing that on larger files, say anything over 20GB or so, the file will only cache around 3/4 of the total. I monitor the throughput on my ISP app and it will go from my max speed, right down to zero even though the entire file has not been cached. This will only happen on larger remux files, for example 3-5GB tv episodes will load all the way through. My current fix is to exit out of the file when I near the end of the cache, then just hit resume instantly. The file will then cache the remaining 25% or so. While this is a workaround, it’s driving me crazy why infuse will not cache the entire file. I thought it was maybe my ISP but I have ruled this out I think.
I’ve changed the cache setting within infuse to Legacy, Memory Only and whatever the other option is-no help, anything other than Auto makes the problem even worse.
Any suggestions are appreciated.
