Hi there
I just wondered if there was a web based management interface for atvflash so that shares/settings etc could easily be managed from a PC rather than use the remote?
Thanks in advance
Paul
Edit-sorry wrong forum
Hi there
Thanks in advance
Paul
This is not possible at the moment. However one does not change them too often so it is not that big a deal. If you have one, you can install the BTStack package (although I am not sure if that is yet compatible with 5.0 firmware) and use a Bluetooth keyboard which can make entering settings easier than using the onscreen keyboard via the remote. There is also the Remote app for oPhone, iPod Touch and/or iPad that has keyboard support.
As to whether a web insterface might appear in some future release I have no idea.
Thanks for the info - up and running nicely now.
