Weather in Celsius
Hey,
Does anyone know if it’s possible to change the weather app to show temperatures in degree Celsius (centigrade)? All of mainland Europe, and most people in the UK under the age of 40 have lost the power of understanding Fahrenheit! :)
Yes, you can change this setting by navigating to Internet --> Weather, view the location you want to adjust, press/hold the center (select) button and choose the edit option, then adjust the setting(s) to fit your needs.
Ah, it’s per location - hadn’t guessed that!
PS. In the UI should be spelled Celsius, not Celcius  :stuck_out_tongue:
Thanks for the help!
Whoops. Thanks for pointing that out.
We’ll be sure to get that fixed.
