Weather feeds for nito codes
managed to get my atv black up and running but where do you get the weather codes from for nito weather . just have the 4 european ones and i want my area in the uk .
join the club, i added my post code and it now comes up with the weather in chicargo and i cant get back into the weather menu to change it back !
Go to http://uk.weather.com/regional
type in your town in the search box and your resulting page will have the code in the address !
i.e.
http://uk.weather.com/weather/today-Chatham-UKXX0780?fromSearch=true
thanks for that . i will give it a go .
thank you mate
Same goes for anywhere in the world, Just look at the URL and for example it's UKXX0780, For me it's NZXX0006 so just look at that and you should be sweet.
Thanks alot for your help. Works great.
