Admin/admin not working on infuse 5/ATV4/WDMCH for me.
I thought the admin password was blank by default? So username: Admin and no password - try that?
I’m about to buy a WD My cloud Home 6TB single bay. Does this have issues with Infuse?
I’ll speak in generalities on this. First, there are two versions of WD My Cloud NASs, one is a “MyCloud” and the other is “MyCloud Home”. From what I’ve been able to glean there are far less issues and problems when using the MyCloud with Infuse. The MyCloud home is lacking some in what most people use for streaming at home.
I have a MyCloud and it’s been flawless for over a year of being my primary media server.
Sorry I don’t get it what is missing? Pnp, Samba? I have an old Lacie network and I never had a problem with infuse or aTv Flash. So the My Cloud home is not working with infuse?
Or is just some users that have issues. Usually to connect a network HD you have to use the guest user
Did you read this thread? There are several posts that reference the issues some were having with one version over the other. Between this and some other threads here (and on other sites / Google is your friend for that) where there were issues connecting via http and other anomilies the “Home” version seems to be a bit more of a challenge to set up and keep working.
You may or may not have any issues but just from what I’ve seen I’d choose the non home version personally.
There are so many other factors that may come into play you may just have to forge ahead and see what your experience will be.
really?
thanks for the help I’ll test it myself
Not really sure why the sarcasm. You didn’t mention that you had read any of the above problems and their possible solutions with the Home version. When you responded with
It sounded as though you may have missed the posts about connecting to public folders and how to enter admin info so I just asked if you were aware of the problems already brought up.
I’m more than happy to try and help with issues but you have to remember, there isn’t any emotion in text responses (I’m not real up on all the smilie faces) and when a question is asked of you it’s not usually meant in a condescending way, just trying to figure out what direction to try next.
There’s a great chance that you’ll have no issues at all but you asked if there were any issues and I was trying to point you to some that had previously had problems.
Just for people who land on this thread, like me, and who can see this ended in the usual forum s@$ storm of misunderstanding, I thought I would offer a solution that worked for me:
- For some cra cra reason, the permissions on the WD MyCloud’s are whacked, but they do make a mysterious ‘Public’ folder available to anyone on the same LAN… trouble is you can’t see it (per alll the messages above)
- The way to make it visible is to map a network drive against that folder (i.e. \192.168.0.x\public) and then copy your media files into that newly created share
Hope this helps the next searcher of the truth!
I was able to map out the public folder, which is the first breakthru I have had since purchasing a Home Edition a few months ago.
I had already copied my entire library to the WD Home, is there a way to “move” the files instead of copying them to the /Public folder. It took several days to do the initial copy?
I finally was able to connect my WD Home to my AppleTV and inFuse 6. Here is my guide for dummies on the process, because I am a dummy.
I have read through all the post here on this topic and found that WD community forums are not very helpful and WD’s support network is useless. Why use WD at all, well if oyu are like me you just wanted an entry level NAS to use with my ApptleTV. I will one day get a Synology, but I am not a heavy user, but love tinkering and it seems WD is the way to go. Oddly enough I had a WD MyCloud (not the home edition) and I got the home edition only because it appears to support a bit more trans coding, but elsewhere on this forum it is stated that the WDMyCloud is a better bet. I also briefly bought a Buffalo Linkstation, but returned it as it looked like it was going to be a a chore to get it to work as well.
The part I had difficulty with the post here and my lack of networking prowess was understanding when and where i need to use my user name and password and which one? My WD Home user/pass?, my network pass to connect to my NAS? So, I will state my steps below and perhaps it will help someone avoid many many weeks of trying to get these things to talk to each other.
For some reason the easiest way to get access is through a hidden “public” folder on the WD Home. Dont ask me why, just that I read it here and it worked perfectly.
On the MacOS
Command K (which is the keystroke to “connect to server” on the Mac. You will need to know the IP address of you WD MyCloud Home. If you browse and select the WDMyCloud-PA27DH you will only see Time Machine is the resulting connection. There are a number of ways to discover the IP address, look around for that information. Once you have it, put it in the Command-K search box followed by /public. In my case it was 192.168.0.10/public and connect with guest privileges. This resulted in the hidden “public” folder on the WD Home being mounted on my desktop. In order to have access to this folder in the future, make an alias of the location by control clicking the “public” network icon and selecting “make alias” from the drop down menu. In this manner you will be able to mount the public folder later with a single click.
Copy your content into the public folder
One the AppleTV
Start up inFuse
+Add
Under Available Share select: Other Name whatever you like
Protocol: SMB
Address: Same IP address you put in the Command K MacOS search bar with the /public at the end.
Username: (this is the part that I kept having issues with, but what worked flawlessly for me was the username and password that you use to log into you WD MyCloud Home, My Cloud Home.
Save
That was it for me, connected instantly.
Hope this helps and thanks for all the support here at FireCore
I have tried as above with no success at all.
The Mac doesn’t find the IP address with the /public all I can get it to do is the time machine backup.
I’m lost with this now as I wanted to not us the plex part and just use it directly with infuse as I did with a older nas. It worked perfect using it that way. Why didn’t WD allow it to be a normal NAS too!!!
It very frustrating to say the least.
How did you obtain the IP address of your MyCloud Home?
So I got a new (my first) 4TB NAS yesterday and spent all last nigh trying to accomplish what I though would take a few minutes! It’s a Western Digital MyCloud Home 4TB, plugged directly into my Google WiFi puck (main device). I presume I should select network share, and after that I’ve named it, typed in the log in e-mail address and password for the WD NAS but cannot see anything. I eventually got a public folder, but it was empty (there is no folder by that name on the NAS)
I have obviously transferred all of my Movie/TV show files successfully to the NAS. My previous infuse set up was a standard portable 4tb drive plugged into TP link router by USB, so the whole NAS thing has me lost.
I see people have had trouble with this in the past but cannot see any resolutions.
I can set up plex in the nas as a server and it will see everything, will set up fine and work as it should, BUT I want INFUSE!!!
Any help would be greatly appreciated otherwise my Wife and kids are gonna be neglected and ignored this weekend while listening to repeated expletives from me trying to fix this!
For me I use a browser on a computer and go to an address like wdmycloud.local and then you set up users with passwords and also set up shares and permissions.
That’s to start, and don’t use DLNA to connect to the WD, I have great luck with SMB.
I created a user just for Infuse so I could isolate that from other users.
Appreciate the response, but cannot find that URL anywhere, doesn’t seem to exist. If I sign into mycloudhome online, I can see I’m a user and it give me the option to “add user”, but if I type in an e-mail address it just says “invite?”. I’m not sue what all this means, and I cant see anywhere to set up shares, permissions etc. Very new to this. Do you have mycloud OR mycloud home…?
I have the MyCloud, doesn’t the home version have some type of local management instead of having to go to an online source?
Just read through the MyCloud home manual and I have no idea on how to approach the set up for using with Infuse. Hopefully someone who has worked with one will chime in here. Sorry. I would really have no use for the Home version with the dependency on internet connections. The plain vanilla single bay MyCloud works fine for me but have been looking at some of the Synology line as a possible addition.
Thank you! Really appreciate you trying. Would I be right in saying if I use infuse app off the plex server on the NAS, I am then in fact using the infuse player, and not the plex native Apple player? Some of my files are 20-25gb, want to avoid putting any stress on the NAS
