Watching Netflix using XBMC, only PC though
Check this out: http://blog.climers.com/post/2009/01/21/A-Solution-for-Streaming-NetFlix-on-the-AppleTV.aspx
After following the instructions from the link, I have netflix running but it is buffering like every 20-30 secs…anybody know how I can fix this?
I don’t have a PC so I haven’t tried this. Go to XBMC and then to Settings > Video > Player > Cache and double the cache and see if that helps.
Thanks for the feedback, I tried doubling the cache and that didn’t help. So I connected my laptop to the router via ethernet, and netflix played back perfectly.
I guess I was just hoping to be able to do it wirelessly which apparently isn’t possible in this situation. On the plus side I will save $30 bucks not buying PlayOn, and just continue connecting my laptop directly to the TV.
