Watched history not syncing to Feiniu
Infuse version: 8.5
Device: iPhone / iPad / Apple TV
Server: 飞牛影视
Issues:
1. Playback progress does not sync back to the server
  • Play a video in Infuse connected to 飞牛影视
  • Exit midway
  • Check the watch progress in 飞牛影视 app/web → progress is not updated
  • Resume in Infuse → starts from the old position saved by 飞牛影视, not the latest position from Infuse
2. External subtitles are not detected
  • Video files have external subtitle files (.srt / .ass) in the same folder with matching names
  • When playing through 飞牛影视 (Jellyfin connection), Infuse does not show any external subtitle tracks in the subtitle menu
  • The same files work normally with other clients or when mounting via SMB
Notes:
  • Manual adding as Jellyfin server works for browsing and playback.
  • These two issues still exist on the latest 8.5
Happy to provide diagnostic code / logs if needed.
Hello Infuse Support,
I’m experiencing an issue with Infuse when using it with both Feiniu Video (FN tv) and Jellyfin.
Whenever I play a new movie or TV show, the playback record is not synced to the Up Next list. As a result, newly played content does not appear in the list, and I cannot easily continue watching it from there.
This issue has been occurring for a long time, and I hope your team can investigate and fix it as soon as possible.
If you’re able to install the 8.5.3 update, confirm the issue still happens, and send in a report from your device (and post the code here) we can look further into this.
the code is: 2GT1Q
We have a fix for this coming in 8.5.6.
The underlying issue is Feiniu us using API specs from older versions of Jellyfin. We have asked them to start using the newer APIs to avoid issues like this in the future, but for now we have added some special handling.
Confirmed fixed in the 8.5.6 TestFlight build. Thanks, James, and thanks to the team for following up and getting this resolved. Really appreciate it! :folded_hands:
This should be resolved in today’s 8.5.6 update. :slight_smile:
