Watch progress from Vision Pro not syncing to other devices
Hi Infuse Team,
I’ve noticed some unusual sync behavior with Infuse on my Apple Vision Pro.
When I watch something on my iPhone, iPad, or Apple TV, the watch history and progress sync correctly and appear on the Vision Pro.
But not the other way around – if I watch something on the Vision Pro, it doesn’t show up as “recently watched” on my other devices (like Apple TV), and the playback progress isn’t reflected either.
So it seems that sync is only working one-way, which makes switching between devices a bit inconvenient.
Is this a known issue or is there something I can do to fix it?
Thanks in advance for your help!
Best regards,
Wyne
Did you check and make sure that you updated Infuse to the latest (8.1.7) on everything?
Yep, everything’s on 8.1.7 – Vision Pro included. Still no luck syncing the watch history back to the other devices though. :sweat_smile:
