Maybe I’m having an off day, but I challenge anyone to find this movie in Infuse, either by naming their file correctly (without the TMDB-ID), or by searching for it manually when editing metadata.
You will fail.
Prove me wrong.
You will fail.
Prove me wrong.
Yes, it’s a tricky one. You have to use the bullet point character •
I cannot check if my file name matches exactly at this point as I am not home. But I named it this “Wall•E (2008).mkv”
If you’re talking matching, you can use this search on the Edit Metadata screen.
You’ll get the same results on TMDB’s site, so it’s just one of those tricky titles.
