Waiting for Apple TV Please Help :(
Hi Guys,
I have already posted in the iTunes error code topic but i have not had any responses in over a week so thought i would try my luck here, would really appreciate some advice..
My ATV2 was jailbroken on the IOS 5.1.1 un-tethered software was working fine but for some reason last week it just stopped working (blinking light, will not boot).
I have tried a standard restore in iTunes back to factory but the recovery gets stuck and iTunes states "Waiting for Apple TV"
So i have also tried re-jail breaking the device using the latest version of SeasonPass and iTunes but then the script launches iTunes and just stays at the recovery screen doesn't actually start it?
If i choose to restore the SP IPSW file manually i get error 1600 from iTunes?
This is what i have tried so far...
1) Tried on two different Windows 7 32bit PC's and a Mac
2) Tried different USB Cables and Ports
3) Latest versions of iTunes and SeasonPass
4) Host File Mod
5) Ensured all other iDevices are disconnected from iTunes
6) Tried to restore on Older versions of iTunes (10.)
other than the above im not sure what else to do?, im beginning to worry if its bricked forever?
Any help very very much appreciated
Cheers
