Volume Issue
I have the pro version and am running into an issue where the volume on all files is much less than on other playback apps. To match the volume of playerXtreme, nplayer or AVPlayerHD I have to add in about a 300% boost (I installed all 4 apps, copied three files into them and a/b’ed them against each other). I have tried toggling Dolby Effects on and off but it didn’t make much difference. Any ideas?
In general, Infuse’s volume is set to match what Apple uses in their player. Though if you are seeing an issue with a specific file or two we’d be happy to look further into this.
You can use the link below to upload sample(s).
