Volume control with mPlayer?
Hello All,
I just installed nitoTV and it works great. Have a quick question though. When I load a movie, mPlayer allows me to change the volume. By default, it’s set at about a third of the way. Question is, since I control the volume of my TV, what should MPlayer’s volume be to get the best sound? It’s a little confusing, since the normal Apple TV doesn’t give you volume control, since you would normally set that through your speakers or TV.
Thanks!
