Volume Boost Not Working with Atmos Spatial Audio
Infuse 7.7.4 on Apple TV.
Tried it with AirPods Max. I’m able to boost standard multichannel tracks as usual, but can’t boost Atmos.
We need a fix or the option to disable Atmos…
Still not working on 7.7.5.
When spatial audio is active, the volume levels for items with Atmos audio are set by the system and cannot be changed If you want to have volume boost enabled for Atmos items, you can disable the spatial audio option on the Apple TV.
Hello. Thanks for the explanation. I suspected that. We need an option to Disable Atmos similar to the Dolby Vision ON/OFF toggle that we have. Before 7.7.4 I was able to play Atmos tracks as standard surround with volume boost, but now I’m forced to pick between low volume or non-spatial audio. Apple Music app has the option to do that.
Totally agree with OP. It’s super annoying not being able to boost Atmos volume with spatial audio on. We really need a toggle to disable Atmos. C’mon devs, please add this feature!
Todays’ 8.1.7 update introduces an option to disable Dolby Atmos which will allow audio features like Volume Boost to be used with Dolby Atmos content.
This update also does a better job of hiding unavailable audio settings if Dolby Atmos is enabled.
I do not understand this sentence of your post.
if we disable dolby atoms then how can we play dolby almos with increased volume as then atoms is already disabled ?
also in ur next sentence, you said “does a better job of hiding unavailable audio settings if Dolby Atmos is enabled.” what does it mean ? which unavailable audio are we hiding here.
sorry sir for dumb question , but being a infuse premium user, I really need to understand to use infuse to its fullest.
thanks
If you’re playing Dolby Atmos content in Dolby Atmos (passthrough) mode then the options for adjusting any of these parameters are limited.
However, if these same videos are played in Multichannel mode then things like Volume Boost and Downmixing volume can be adjusted.
The option to disable Dolby Atmos will allow these video to be played in Multichannel mode which was previously not possible.
thankyou sir for the explanation.
