Hi everyone.
I just moved from my Shield + Kodi setup to Apple TV 4K + Infuse (Pro). Everything is great apart from one thing and I’m not sure if this is by design or due to something wrong on my side.
When I’m playing a video from my NAS and I fast forward or backward, the TV goes black for a couple of seconds due to a change in the output format.
I have Match Dynamic Range and Frame Rate turned on (which is a must), and I expect this to happen when I start or stop playing a video. This was the same with the Shield and Kodi.
But it doesn’t seems right that it also happens when seeking an already playing video. For example, if I play a video in Apple TV+ app, I get the expected switch when the video starts but not when I seek. From what I can see, this behaviour only happens in Infuse.
Is this expected? It’s definitely annoying and I don’t know if there’s a setting somewhere that’s causing this.
I tried changing the default video output from 4K Dolby Vision to HDR and different frame rates and it didn’t make any change.
Thank you
