Hello there,
Same problem. Stuttering with the sound.
I hope this issue get a solution soon.
Thank you and best regards.
Hello there,
You may want to try the 7.3.1 update to see if that helps.
Also I believe that the stutter being referred to in this thread is video stutter since some of the posters refer to audio being OK.
Hello NC_Bullseye.
Iāve got the 7.3.1 version.
Itās weird, my video is Ok, but my audio has a little āmicro cutsā during the playback.
Is that using AirPods or through sound system?
Hi munpip214, through sound system.
The sound itās ok at first 30-40 minutes. Then, start to stuttering, during 15-20 minutes. After that, then the sound ok again 30-40 minutes⦠and maybe till the end Ok, or maybe the ācycleā repeat again.
I think this error it has been caused by the last update of Apple TV, because before, everything was going fine. I have Infuse since a few years, and never had a problem like this.
Best regards.
This brings up a couple of questions, first what are you using for a file server and second, if the stutter is somewhat repeatable could you try changing the streaming cache from auto to āLegacyā in the infuse settings and see if that changes things?
This sounds like itās fine to start with and then either the server may have to wake to send the next big pack or it could be something in the background maybe another app taking up processor or network time when it incorrectly thinks their inactive.
What device is this happening on?
Is this affecting all files or just a few?
Are you using variable speed playback at all?
Can you send in a report so we can look into this?
Hi NC_Bullseye,
I used the app for AppleTV and the files are storage in a Synology NAS.
There is no āpatternā in the stutterings, I mean, If I rewind the movie and playback again, the same part, sometimes thereās stutteting, and sometimes not.
I will do your recomendation about the config of the app, and Iāll keep you posted.
Hello James,
Iām using an AppleTV 4rd gen.
This problems affecting to all files.
Iām using the speed playback normal.
Iām thinking one thing. The sound goes to the TV and also to a receiver (I mute the TV and only listen the receiver). Iāll try to playback the file with the sound only throught the TV speakers, not receiver, and Iāll tell you.
Because, maybe the problem is not in the app but in the receiver. It could be just a coincidence that the update and the fault (possible) in the receiver, had happen at the same time (weird but not impossible).
How is your system connected?
Hello there!
Well, after make the test with the playback of one file with the sound only through the TV, I have to say that there was no problema at all. With that I can say that my problem is with the connection between the TV and the receptor A/V. Maybe de cable HDMI or maybe the connector in the receptor itself.
From my side, the problem is solved (not solved but I understand where its coming from)
Check your connection path. Make sure itās AppleTV ā> amplifier ā> TV. Donāt use ARC to deliver the audio to the receiver. Additionally check for firmware updates on your amp.
It might be an older receiver that doesnāt support hdmi 2 or 2.1 or 2.1a ![]()
