I’m interested in the new Apple TV 4K and infuse and need some information.
Do the box and the application support HDR10+? single and double layer Dolby Vision? The AV1? The VP9-2?
And for audio is it possible to have HD audio? Dolby True HD? DTS-X? DTS HD MA? Dolby Digital+?Dolby True HD Atmos? Flac ? 24 bits 192 kHz ? I have read conflicting sources, some say there is no HD audio because it is only in LPCM and it is not as good and others say everything is available but in LPCM and that it is of as good quality as normal formats because it is compressionless and lossless.
See the bottom of the website for list of supported formats. No HDR10+ Only Dolby vision single layer profile 5. LPCM supports lossless HD audio without Atmos. Atmos supported only in Dolby digital+
I saw that the new Apple TV 4K was able to do Youtube 4K HDR. So that means it supports both hardware and software VP9-2, can you confirm? On Infuse too?
Just FYI, the Zidoo and Dune media player don’t support profile 7 playback like UHD BD players do. Instead of “correct” playback of BL + EL + RPU they only use the BL + RPU. Apparently this is even been done outside of the Dolby SDK.
It would be great if you can explore this possibility as well.
