very simple to run tiny umbrella v.5 and seasonpass and 4.3.0 ipsw
I had being several hours trying to restore my appletv 2 after a crash… and after many times in the end it was so clear…
1: download tiny umbrella… the latest version
2: i supposed you have season pass also the latest version
close all apps… connect  your appletv plug first and the the usb cable
open tinyumbrella… you will see in upper left window… your appletv device… select it…
press save shsh… go to the log window… if it found the shsh in cydia… its perfect… but if not just unchecked request shsh from cydia in the advance window… and press again save shsh… mine find it throughout apple
if you have shsh files your almost near to success!!!
okay… then… if you find it through apple… unchecked set host on cydia… if not… leave it like that…
i closed tiny umbrella, disconnect the power cord and open season pass, let finish… and enter dfu mode.
itunes will open, and all by itself opens the restore file… just wait and cross fingers…
tata!!!  please tell me if this works for you!!! really i spend hours trying with different cables, trying to connect to tsp server, many things, and this was that worked for me!!!
