Use iPhone 4 as remote
Hi all
I am sure this has been asked many times before but with the latest realease I was wondering if someone could give me an definitive answer.
I would like to control my 1st Gen ATV from my iPhone. I have thestandard base build and XBMC, thats it TBH!
I would like to be able to use my iPhone to navigate the base IOS and XBMC via a track pad or cursors.
Could some one give me some answers and links please.
Cheers
Take a look at the free Remote app (http://apps.firecore.com/remote) or Remote HD (http://apps.firecore.com/remotehd).
Thanks for the quick reply. A few more things. Apple free Remote, will that allow me to control XBMC on the ATV> Remote HD, I tried the free version and wasnt to sure about it as it kept loosing connection between the adverts coming up on screen,wasnt best pleased so removed it.
I also tried mouse air remote but couldnt get that to navigate the menus in te base ATV flash system
I also tried mouse air remote but couldnt get that to navigate the menus in te base ATV flash system[/quote]
The free Remote app will allow you to control the native AppleTV menus only. Remote HD will do that, and other applications like XBMC as well.
