USB hard disk drive ?
Hello people.
When will it be possible for the Apple TV2 connect a USB hard drive? Did the IOS version 4.4.4 on the device.
Thanks in advance for the answers.
If you mean directly to the ATV2 then that is not going to happen.   The hardware in the ATV2 USB port is capable only of working in Slave mode whereas it needs to work in Master mode to support a USB drive.
OK. Thank you for this info Too bad
suggest start looking at connecting a USB drive to your router instead.  Many have done this with AIRPORT EXTREME router, with lots of success.
