I’m playing videos from Emby and getting a mirrored display issue. You said it’s a system problem, but when I use the mirror feature in other players, everything works fine. Why is Infuse so special?
Prior to Infuse 8.5.4 when I plugged in my portable 13 inch display and played media it would have the controls and art on the iPhone screen and output the actual media to the screen. No video would play on the iPhone screen. Now its just a mirror of what’s playing on the iPhone display which means it doesn’t fit the external display quite right and I have two screens playing the same video (which is annoying, but not as annoying as the resolution issue).
The display is connected with a USB-C cable and I suppose it uses HDMI as it’s transport.
I will also say that at the same time Infuse was updated, I updated my iPhone 15 Pro to iOS 27 RC, but I did run the 27 beta all summer and the problem did not exist.
Thanks for any help!
Just chiming in to say same issue here using Xreal glasses over USB. Worked this morning, broken this evening.
I’d also love to see this fixed, thanks.
This is, it seems, linked to iPadOS 27.
Checked on an iPad and iPad Pro.
@james , can you reproduce the issue (on any iPad running iPadOS 27 with an HDMI output - and screen mirroring option selected if selectable)
My iPad is on iPadOS 27, with Infuse 8.5.3 and it works as expected there. My iPhone is on 8.5.5 and it’s broken. I don’t think the issue is caused by 27.
I installed infuse(latest) on an iPad running iPadOS 26 yesterday. A movie played as it should, occupying the whole 16/9 screen, over HDMI.
Updated to iPadOS 27 today and the same movie only occupied the 4/3 part of the screen over HDMI.
Same issue with an iPad Pro running iPadOS 27.2 beta and various 8.5.x versions of Infuse.
Playing on external display from iPad via HDMI (with a USB-C to HDMI adapter) is broken, with display mirroring enabled: the 4/3 iPad screen is mirrored to teh TV instead of the video occupting the whole 16/9 display area. It works OK with extended display mode, but that is not available on all iPads.
With the same settings, the Apple TV app and Canal+ app still work correctly.
I believe this is with iPadOS 27 - it worked fine on saturday on an iPad running iPad OS26.x, and not on Sunday after updating to iPadOS 27.0 with the same iPad, media file, USB C to HDMI adapter and TV.
Diagnostic code made with an iPad Pro 12.9" M1 and iPadOS 27.2 beta (24B5089g) and Infuse beta v8.5.6 (5755): 356RT
Thanks for the reports. This seems to be a new behavior with iOS 27 and we’re looking into this.
Am I missing a setting for external display size/aspect? I travel a lot with my iPad and a USB C to HDMI cable. Previously playing stuff in Infuse displayed full screen on the TV. Now it has huge black borders all the way round, I know the iPad can see the whole screen as when I get notifications they appear right at the top of the screen. How do I make Infuse play the video full screen like it used to?
@Plasma same here. It’s been moved to a dedicated topic
Thanks @jrmec.49364 ![]()
I moved both @Plasma and your post to that thread ![]()
Same issue here when I use my Viture Glasses. Just a mirroring. Really annoying.
Also it would be great at the same time to allow the device to be locked when playing the video. Before, with infuse, the device neeeded to stay on infuse with the display on. When we locked the device, the image froze and there was only the sound.
I don’t have this issue with other app. I can watch a movie and lock my iPad.
Can we expect a fix in the next release, or is it too early to tell?
Thanks in advance.![]()
+1. I’m using mostly Infuse with my Viture Glasses and the experience is now pretty poor. A quick fix would be appreciated. Especially knowing the fact that other apps, even with IOS/iPad27,don’t have this issue.
Any update please? @james
Has there been any progress made with this? It’s been nearly a month and two app updates of being unable to use Infuse for my primary use case (which is why I pay a subscription). I’d have blamed Apple, only every other app seems to work just fine in this regard since iOS 27.
As asked by James in a related topic AirPlay/Screen Mirroring broken on IOS 26 - #59 by james , here is some additional info
1 diagnostics code T4E4B (iPad Pro 12.9" M1 running iPadOS 27.2 RC 1 with Apple’s official USB C to HDMI thingie and a 4K DV capable TV)
2 Happens for seemingly all videos. Both 1080p H264 and 4K DV or HDR10(+) tested.
3 Tested with videos stored on the iPad’s local Infuse storage and on OneDrives.
4. I just get a copy of the 4/3 iPad’s screen on the 16/9 TV. WIth big black bars on the side.
4b. Airplay (including screen mirroring via AirPlay) to Apple TV from Infuse seems to have the same issue but in my experience it’s never been really reliable anyway, and this is not the issue I reported here.
It seems this is related to the recent changes Apple introduced in iOS 27 regarding background external display scenes (UIWindowSceneSessionRoleExternalDisplayNonInteractive), which now require applications to explicitly declare and register scene accessories to manage non-interactive external video streams properly.
So you need to apply thèse changes into the app.
Hi Infuse Team,
Since updating to iOS/iPadOS 27, Infuse no longer recognizes my external display device (VITURE XR glasses connected via USB-C) for native video output, and instead defaults to simple Screen Mirroring.
The issue:
Previously, when playing a video, Infuse would successfully hand off the video stream to the external display. The glasses would get the perfect native aspect ratio, and the iPad screen would display the “Playing on external screen” overlay, allowing me to safely lock the iPad screen without interrupting playback.
Now, it only mirrors the iPad’s display. If I lock the iPad, the video playback stops completely or the glasses simply display the iOS lock screen.
Technical context:
Could you please look into updating the external display implementation to support the new iOS 27 framework layout?
