USB drive not primary
I’ve followed the procedure mentioned in http://wiki.atvflash.com/index.php?title=USB_Storage
The disk is now mounted, can find it also via FTP, but the size indicated under info or in iTunes
on my PC ist sill the size of the built in HD instead of the externals USB HD ? Meaning I can not
synchronize my iTunes library at the moment …
Anyone a solution for that ?
There used to be a telnet procedure on the atvflash site, which I can’t find anymore …
Sounds like you setting up the drive as secondary not primary …
If the volume label of the drive shows up in NitoTV > Files or … when you FTP it shows as a link inside Movies Folder then it must have been set as secondary…
