USB Drive as Media database with Boxee. PLEASE HELP!
Hallo everybody,
since a longer time I am desperately looking for a solution to use my USB 1TB drive as database for mymusic under Apple TV and Movies under Boxee. Now a new try with the new software from January 2009.
Please help me. Boxee doesnt even see a drive (or where do I need to look for the mounted drive?).
Then I tried to do the trick from the wiki page to exhange the internal HDD vs the external USB drive. Yesterday it did not work because it could not copy the media.
Today I get this message:
t-h-macbook:~ TH$ ssh frontrow@appletv.local
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that the RSA host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
36:07:c2:a6:0c:64:01:fc:a1:e7:09:7f:be:1c:8d:5d.
Please contact your system administrator.
Add correct host key in /Users/TH/.ssh/known_hosts to get rid of this message.
Offending key in /Users/TH/.ssh/known_hosts:1
RSA host key for appletv.local has changed and you have requested strict checking.
Host key verification failed.
Can somebody help me to find the easiest way??
Best regards
Th1981
For that message you have to get rid of the known_hosts file on your Mac. To do that open up Terminal and type:
rm ~/.ssh/known_hosts
That should allow you to reconnect to the Apple TV.
