No problem getting ATV to recognize my 160gb, even though it did say something about syncing with iTunes somewhere along the line, even though, I thought the whole
idea was to put in all my files (ie my dvd collection) , or for that matter .wmv files and that when I went to Nito, Files, it would show my USB hard drive with the movie files
inside. If that is supposed to be the purpose for an external HD, I am not quite sure why the ext HD has to be synced when just purely being used as a Secondary.
Also, in the description for use as a Secondary USB HD, it said that it perhaps should be used to put in NON iTunes related files. I guess that would mean for example .mpeg files
.wmv etc, .avi… The big question is, I went to Cyberduck, and found my newly installed usb HD in /Movies. I figured that I could copy or move all these non iTunes related movie files
to that HD, however, for some reason when I click or double click that HD, it doesn’t open for me to move movies into it… Should I be able to? If not, How does the process go to get into that external HD from my Mac Desktop (or Cyberduck?)
