Hi there!
can I use this manual
http://www.iclarified.com/entry/index.php?enid=971
to make USB enabled?
Hi there!
Yes, you can use that guide. Our software enables SSH access which is required for USB drive enabling.
I have a Windows Vista machine. If I purchase an OSX Tiger DVD, would somebody from this site provide me with the USB activation fix on a USB drive, along with the 3.1 update and the flash fix so that I can play content from Hulu? Thank you.
