upgrading an old jb to 5.3 now stuck looping ... help
hey there
jb my atv 2 about a year ago maybe 14 months
haven't done much to update it and wanted the wwe channel and saw i needed to update
downloaded the newest Seas0npass everything appeard to go fine however now it looped and looped on the logo
now its flashing and the screen is black
if i plug it in and try and do everything over it all works
but im missing something probably to do with how old my jb was
i downloaded an older seas0npass it said for older atv's that went to itunes to execute a script
but it just fails
im not sure if im supposed to restore in itunes
anyway any help would be appreciated
and again apologies for being a guy who stumbles through and forgets everything a month after doing it
even if i could get back to 4. whatever
just so i could actually watch tv again
What version of SeasonPass are you using - it needs to be 0.9.5 for the latest jailbreak.  Any earlier version would give the symptoms you describe.
You should be able to do a restore in iTunes to get back to a non-jailbreak state.  That will put you onto the latest 6.x series firmware.  If doing that fails then whatever prevents that working needs resolving before attempting to go any further.   After reverting to standard firmware you can try re-doing the jailbreak which if it succeeds will revert the firmware version to 5.3 firmware (albeit with an untethered jailbreak).
I think I have it working now.
I believe the problem was that I was using the newest version and it was too recent
with my original being 4.3 i think
i restored with itunes and then reattempted to jb
its on the network but not wireless as my right button is borken on my remote
hopefully have everything resolved tonight
thanks for the response
