Upgrade harddisk
I want to upgrade the harddisk of my atv myself.
I found all the howto;s, but I am not sure which hd to use?
I bought one today with out looking closely to the interface and bought a sata drive.
Stupid question maybe, but is the atv harddisk ide or ata (or is this the same?)
Which models can I use and what is the max disk size available?
Hope anyone can help?
I have used this drive:
http://www.buy.com/retail/product.asp?sku=205540167&dcaid=17768
Works great, and I have my original drive, with the default install as a backup.
Thx! Will have a look at this one than.
sadly unlike every other Apple computer, the AppleTV uses an ATA interface, not SATA.
which limits your range of maximum hdd size a bit more than SATA too :(.
but yes, they are quite different & incompatible.
& it’s always good to keep the original hdd in case you screw up the hack :slight_smile:
