Upgrade from 3.2.2 to 3.2.3 question.
I have to restore apple tv to factory settings and then install 3.2.3 or i can install over 3.2.2 ???
Thx.
Yes. Refer to my post below which has helped me cope through the days:
http://forum.atvflash.com/viewtopic.php?f=6&t=271&p=1295&hilit=folder#p1295
Any new ideas are welcome.
You don’t need to restore apple tv to factory settings. Just install 3.2.3 over 3.2.2. All your previous files/hacks will still work as before the update to 3.2.3. The only difference I’ve noticed is the “new version of nitoTV (0.5) which greatly improves video playback and metadata handling”.
But nothing to do when playing .mkv files 720p … :frowning: :cry:
tried also to copy on ATV hard disk but nothing … sob
