Hi.
I have XBMC installed through my Atv flash black. How can I update me RC2 version to the new one that came out here on the 24th? I do not have the option to upgrade within the Maintenance menu?
Hi.
on my atv-silver I just downloaded the OSX version from xbmc’s site and extract the dmg. Then I copied the files over the RC2 version. I used WinSCP to copy the files. I don’t remember where exactly the files are on the atv.
Solved. Got it to update through NitoTV. THX
Updating without nitoTV
What If I don’t wan’t to lose all my custom configs on my RC2 and want to upgrade it without removing it??
back up and then restore after upgrade the userdata folder.
