Updating Adobe Flash Player
Went to watch the Super Bowl commercials at www.superbowlads.fanhouse.com.
On screen flash area displayed "you need the latest version of Adobe Flash Player to view this content" along with a link to the Adobe website.
My question is:
Will running the adobe flash player installer work with aTV flash, 1st Gen ATV, or is there another route to take?
P
Nobody has an answer!   :(
Not even a moderator?
Maybe if I rephrased the question:
How do I update the to the latest version of Flash Player on my 1st Gen ATV?
P
Unfortunately Couch Surfer does not currently support Adobe Flash. There is limited support for Adobe Flash in Firefox and Boxee, and more details on enabling it in these applications can be found in the link below.
http://support.firecore.com/entries/259320-enabling-adobe-flash
