Updated to 1.3 Still no View Type in Media Settings
For some reason Ive never been able to see this in the menu in Media - Settings!
Can anyone help pls?
Which version of AppleTV software are you running?
(check in Settings --> General --> About menu)
4.1.1
Didnt want to update ATV incase I couldnt use Atvflash etc
If you’re running 4.1.1 you’re probably running a VERY old version of Media Player as Beta7 and later will require AppleTV 4.2 or later.
Your best option will be to re-jailbreak with the latest version of Seas0nPass. This will update your AppleTV to 4.4.4, at which point aTV Flash (black) can be re-installed.
Thanks!
