Update aTV Flash 4.1.5 not working
Hi - as always, a dumb question. Is this downloaded and put onto a usb and put on the atv thru that? Will that affect any content or settings I already have on there or is it just a user specific patch of some sort?
2 - I did move back to xbmx previous version (i had downloaded Dharma) as you suggested and my issues were resolved. Does the fixed version allow for dharma to work or should I just leave the download and stick with this for now?
Thanks again[/quote]
If you have aTV Flash currently installed you can updated through the Maintenance --> Manage Plugins menu. If not, you will need to reinstall via USB.
The nightly Dharma XBMC builds are available through the XBMC/Boxee --> Downloads menu when running version 4.1.5 or later.
 New user. Installed successfully but no new menu. What do I do next?
[quote="amarjitn.2875"]
[/quote]
Do you have an alternate flash drive you can try using?
