What a disappointment. While the app is fantastic, none of the feedback regarding:
- indexing (À, Æ, É….) sorted after Z,
- the issue with the button “return” on Apple TV,
- the file movies vs. files series in the library, indexed as folders
Seems nothing has been took in consideration … So, can’t wait for 8.2.1
Please also post in English so that more users can benefit from your contributions. Also you may get an answer sooner from others who have had the same problem.
Merci de publier également en anglais afin que davantage d’utilisateurs puissent bénéficier de vos contributions. Vous pourrez ainsi obtenir une réponse plus rapidement de la part d’autres personnes ayant rencontré le même problème.
Hi there this is for technicians :
- the issue with the button “return” on Apple TV (have to click twice or wait over 5sec)
- Metadatas are not updated correctly (ex: have same movie 4K DV … but with two different weight or two different video bitrate. The metadata will remain the first one i download) If want to update correctly need to erase all metada data and reload everything. Including the files created by myself.
Seems nothing has been took in consideration … So, can’t wait for next update or 8.3
