I have 2 movies libraries on Plex - one with just HD content, and another woth HD and 4K content. The 4K one consists of the same folder that is in the HD library plus a 4K folder. I have not enabled the HD library on my Infuse, but when playing a movie from the 4K library, and stopping it, I get 2 instances of the movie in “Up next” because there are 2 versions. Can I somehow clear that?
Same issue here, it takes up way too much space! Wish there would be a way for infuse to just show the version you watched only instead of putting 3 versions of the same show/movie in up next, wasting space for other content.
I’ve found this is because infuse shows the progress of all media from a plex server. Not adding a particular library to the infuse homescreen doesn’t seem to make infuse ignore that library as such it just doesn’t show it as a folder on the homescreen but any media partially watched in it, will show on the homescreen. Is there any reason you keep the libraries separate? I haven’t had mine separate for years now and the plex app always chooses the correct version of the movie or show to play based on the hardware its being played on. Infuse always asks me which version I want to play before beginning playback. Merging the libraries will also result in continue watching only showing one item.
