'Up Next' not displaying whilst using Jellyfin Direct Mode
I have been using Infuse for years in Library Mode and the Up Next row at the top of my homepage works fine. I am now using a large Jellyfin server in Direct Mode and the Up Next row is not behaving as it should. It will displays Recently Added fine, but when I set it to Watching Only it doesn’t display anything I’m watching. How can I fix this?
Were you ever able to get this fixed? I’m having a similar issue with a large JF library:
as mentioned in other threads, this is intended behaviour.
the “top row” on tvOS will only every display the “watching” row and won’t display “next up”.
this is because jellyfin has splits this as 2 separete things, wheras plex combines it into 1.
No, my issue was that the „Next up“ content was nowhere to be found. I’ve moved from a jellyfin server to emby because of this problem.
nowhere to be found where exactly?
the only place it doesn’t show is in the tvOS top row. otherwise it shows up just fine.
emby and jellyfin as essentially the same procuct, just different forks.
I’m aware. Take a look at my second image above. It might have been an issue with my config of JF, but „Next Up“ wasn’t available anywhere on tvOS, while it showed up fine on other platforms.
