Unwatched filter
on home screen there’s a section: unwatched movies, this lists all unwatched movies in library.
Tv shows, other movies together.
on ATV there is an option Show Library and there can we filter to unwatched Movies only.
On iOS device there’s no Show Library option, there’s no option to list only unwatched movies.
Is there any other possibility to filter unwatched movies on iOS?
You can pin any library category to your home screen by using the Home Screen edit page.
  1. Tap the icon from the top right of the Home Screen
  2. Select Edit
  3. Scroll down to the ‘All Items’ section
  4. Select Movies
  5. Tap the + icon next to Unwatched
Thanks a lot. :pray::blush:
