Hi, I’ve used Infuse 5 Pro everyday for years.
I download tv series episodes from my server for offline watching.
I need Wol active on my Windows 11 Pc but now I recently purchased Infuse 8 and my Pc boot up every time I open Infuse on iPad. I there a way to stop this behaviour? Please help me
Thanks in advance
In Infuse 8.1.9+ you can disable the ‘Auto Scan’ option found under the Advanced section of the saved share’s settings.
Unfortunately I can’t see the Autoscan on MacBook Air and on infuse iPad app
Please check to ensure you are using the latest 8.1.9 update, as this feature is new and was just added in this update.
Thank you very much James!
EDIT: I opened infuse on my MacBook for watching a downloaded episode (I’m not at home) and with Anydesk I see the Pc boot on after a minute. So, problem not solved James ![]()
Problem not solved, I’ve changed the parameters in new infuse version but my windows pc switch on anytime I access infuse
Disabling the option will not block all network activity, so if you browse to a screen which has items from the Plex server displayed (or you attempt to stream something) the server may wake up. This would include the Home Screen if there are items in the Up Next list.
You can try adjusting the PC’s settings if you never want the server to wake.
