I have 2 home movies that are in the m4v container, that Infuse will not let me update the metadata. It keeps referring to them as Untitled Project. I have tried other metadata editors and no luck there also.
Any ideas please.
Any ideas please.
I’d suggest to set up a local metadata file and then you’ll have to do a refresh to get the new metadata to show.
Changing the filenames will make sure Infuse treats them new content, and confirm the issue is inherent in the files.
You can try MKVToolNix to pull the content out of the current container and stick them in new ones that possibly don’t carry over the offending data.
