I have a APT2 running 5.0.2. I want to jailbreak this with Seasonpass but I am afraid that if I do so iTunes will default it to 5.3 and I will have to tether this
sucker to reboot. I want to keep this firmware but after reading all over the web I am discovering I cannot. I’ve tried using TinyUmbrella, looking for the Seasonpass beta version with allowed you to save the signatures. Can someone please tell me what my options are with my situation.
you don’t need the beta version anymore the latest seas0npass still has this feature. Did you try using the lastest seas0npass and it didn’t work? Generally, I just untethered jailbroke a 5.0.2 atv just this weekend. I generally just use ifaith to dump by shsh blob. Then use the seas0npass right-click on the create ipsw choose firmware 5.0.2. Then just follow the instructions seas0npass gives you.
