Hey team,
you can (mostly) change subtitles to display as light grey, etc. when loading a video, which will help you save your eyeballs, but only after enough time passes for your vision to return to you first.
Wasn’t able to find a suggestion for this (or solution for this) while searching, but can we implement universal brightness settings across dynamic ranges? So all HDR/DV media will default to a most reasonable subtitle brightness?
As far as I can see I currently need to manually do it each time I watch a different movie.
