Underlines and double-underlines for most headings
I’ve been assuming the underlines must be due to some known issue, so I haven’t mentioned it, but after seeing a screenshot from @james (Customizable Home Screen favourites - #10 by james), I realize not everyone may be seeing what I’m seeing. The underlines are especially out of place for the library type section, where they are doubled. Have a look at my screenshot: https://firecore.com/sites/default/files/upload/img_7353.jpg
I looked around in the iOS settings and found that they’re showing because of the “Button Shapes” accessibility option that I’ve turned on. I’ve never noticed any apps leverage that setting within their apps, aside from the top-most back button. Have a look at the screenshot to see the setting, and also the top-most back button that is typical of iOS: https://firecore.com/sites/default/files/upload/img_7e5a39a590f4-1.jpeg. I guess the Infuse team is making use of some iOS’ interface guidelines, so I can’t say much more about the regular underline, but the double-underlines, at the very least, I think, should be addressed. The regular underlines I now accept as my own decision to show “Button Shapes.”
Thanks for the feedback.
I’m not sure we have a good way of handling this, as the ‘extra’ underline found under Movies, TV Shows, and Other is a styling element used to indicate which section you are in, but we’ll take a look and see what can be done.
