Unable to switch video streams / HDR format in remux files with HDR10+ and Dolby Vision
I would like to report an issue related to Blu-ray remux / original disc movie files that contain multiple video formats or video streams.
Some of my original disc movie files may include multiple video formats, such as HDR10+, Dolby Vision, or other HDR video streams. However, in Infuse, I often cannot manually switch between the available video streams, or Infuse seems to automatically choose Dolby Vision by default.
This can be inconvenient because, in some cases, I may want to play the HDR10+ version instead of the Dolby Vision version, depending on the device, display, or playback environment. However, there does not seem to be a reliable way to select which video stream or HDR format should be used.
The issue is mainly as follows:
  1. Some original disc / remux movie files contain multiple video streams or HDR formats, such as HDR10+ and Dolby Vision.
  2. Infuse often appears to default to HDR.
  3. I cannot find a stable or obvious way to manually switch to another video stream, such as Dolby Vision.
  4. As a result, I cannot control which HDR format is actually used for playback.
Could you please check whether Infuse can support manual video stream selection for files with multiple video streams or multiple HDR formats?
It would be very helpful if users could manually choose which video stream or HDR format to play, similar to how audio tracks and subtitle tracks can be selected.
Thank you.
By default, if a video contains a compatible Dolby Vision video stream Infuse will choose to play that.
If you prefer to play the HDR or HDR10+ video stream you can disable the Dolby Vision setting. This can be set on a video-by-video basis through the Video section of the Playback Settings menu (available while a video is playing) or globally for all videos in Infuse > Settings > Playback.
If you have a Dolby Vision video that is only playing in HDR then this may indicate the file contains a Dolby Vision profile type that is not supported on Apple devices (such as Profile 7).
